Assign Revit categories in Rhino 🤩
Hello @Community !!
We’ve just released a super cool new feature for Rhino - a whole new interface dedicated to assigning Revit categories to your model geometry or layers. Category assignment works both ways: you’ll get properly categorized direct shapes when you load your Rhino model in Revit for early stage design coordination, and you’ll be able to easily select all objects in a category when you load a Revit model in Rhino.
Read about the details here: Assign Revit categories to your Rhino model | Speckle
And install the Rhino connector 3.7.0 release to test it out :slightly_smiling_face:
p.s. If this sounds familiar, you’ve probably heard of or used our legacy mapper feature. To clarify, this category assignment tool will not create native elements in Revit, and is intended for fast coordination in Revit so your reference geometry play nicely in views and your schedules give you simple object counts.
p.p.s Give @bjoern a hug for sprinting this feature out in under a month💙
Thank you very much, I’m looking forward to trying it. :smiley:
This topic was automatically closed 14 days after the last reply. New replies are no longer allowed.
