Hi, I’m testing the Archicad alpha connecter and the windows are not included in the wall when sent through speckle.
Hi @MSDCA ,
This is on Archicad’s selection logic. When you select a wall, it doesn’t select nested elements on that wall (like windows, doors etc.). You need to specifically select those elements as well.
If you want to send everything from Archicad, there is another option under Selection input. You can send everything from Archicad👇.
