Torben
10 September 2025 16:13
1
Hi! I installed v3 Add-non for Archicad 27 and 28 and both can’t load models from the server. They just create black dots.
The report says
0 objects converted ok, 0 warnings and 0 errors.
Filter:
No items found
I opened the created object and in the 3D-Sript Archicad shows an error (too many parameters at line …)
I installed the last version 3.0.4.
Hey @Torben
The report is currently expected to show 0,0,0, but it should still load the geometries regardless.
Could you provide a few more details?
What was the source application?
Does this happen with any model, or just a specific one?
If it’s a specific model, could you share a link to it? (You can also send it via PM.)
Could you also confirm that Speckle Desktop Services is running on your machine? (You can check this in the system tray.)
It’s also helpful if you share the 3D script where Archicad shows the error
menno
(menno)
9 October 2025 07:46
3
Hi! I’m having the same issue. Elements are imported as empty speckle objects on the 0-point. It happens both for models that come out of Rhino and from Revit. Running latest Archicad version 28.3.0 (6003) and Speckle connector 3.0.6. Speckle Desktop Services is running in the background.
Hey @menno
Do you also have an error in the 3D script of the GDL?
If yes, could you share the script with us?
Thank you!
David
system
(system)
Closed
9 March 2026 16:14
5
