Hello, and thanks for the help :
Objective: Find which Renovation Status (e.g. Existing - New), find Structural Function (e.g. Load Bearing - Not Load Bearing) and it’s Position (e.g. External or internal) in Speckle.
Issue: I expect these properties to be in the file, but I can’t find them. I’m unsure if this is due to an issue with how I exported the file or something else, since I also tried adding the model as an IFC file to Speckle. Could you advise on where I should look for these properties, how to correctly export them, or if these properties are not yet available in Speckle?
Example:
This Image 1 shows that this wall: Being Load Bearing, Exterior and in the Existing Status.
This Image 2 shows that this wall: Being Non-Load Bearing, Interior and in the To Be Demolished Status.
I cant seem to find this properties on Speckle after exporting them
Thanks for the help,
Marco
- Speckle link: main - 3 walls | Speckle
