Adding Pulse effect in the viewer
Hi all!
i was wondering if its possible to add pulse effects in the speckle viewer since im thinking on using the viewer for IoT monitoring.
https://codepen.io/olam/pen/KKMvWM
any help is much appreciated
Of course it’s possible, you would need play a bit with the Viewer code, here is a sandbox project you can use to do so:
Thanks man! yeah i have the viewer running, i can filter sensors, get id properties, change the color and stuff like that but i have no idea where to start to add that kind of anymation.
