While maybe this is not exactly what you’re looking for, the explorer can certainly show data that does not have geometry associated with it (typos included for free ;)).
From code, that would consist in creating a new Base object and adding properties and values corresponding to your data.
thanks for your answer!
Now, I understand. As you are saying, it’s not exactly what I was looking for, but using different branches for the elements and the “project” parameter could be an option.
I’d also recommend adding extra inputs to the sender instead, just zoom in close enough
Each input is set to tree access, so you’ll be sending the entire data tree structure (even if there’s just one item in the list). This is to ensure GH->GH interop keeps track of all data trees and their respective data paths
