Hey,
I have hit a limitation I believe. When using the ACC integration it works fine until I have a published Revit model which contains one or more sublinks(linked as attachment). In ACC these sublinks will shown as part of the host model, as intended(provided the linked file is also in the same ACC hub and it is cloud workshared) but won’t be pulled into speckle. I assume the integration is not finding or does not know it should keep that geometry within the host model. Any ideas?
