ACC integration: moving a file to another folder in ACC doesn't update the model's folder path in Speckle
hi everyone!
When a Revit file that is synced via the Autodesk Construction Cloud (ACC) integration is moved to a different folder inside ACC , the sync keeps working correctly (new versions keep coming in), but the folder path stored in Speckle is not updated ; it still reflects the folder where the file was when the sync was first created.
Steps:
  1. Set up an ACC sync for a Revit file in one folder.
  2. In ACC, move that file to a different folder.
  3. Let the sync run again (a new version is ingested successfully).
  4. In Speckle the model is still shown under the old folder, not the new one.
Is this a known limitation? Could the ACC sync update the folder when a file is moved in ACC? And in the meantime, what’s the recommended way to fix the path ; delete and re-create the sync, or is there a better option?
Thanks for any answer!
