While trying the ACC integration and the intelligence dashboard, I have some random behavior, sometimes it works fine and sometimes not. For example, 3 synced models from the same folder and discipline all come with the same geometry although they are all unique. Another issue is sometimes they do not finish syncing, then if I delete and try again it may go fine. Another issue is in the intelligence, models won’t show up after adding. Usually it appears to work at the start but at some point they disappear and no model loads anymore. Happy to show this in the screen in a live call if helpful.
Thanks,
