ACAD 3D Block to Revit
I’m trying to send an AutoCAD 3d block to a Revit family. I followed the tutorial page, but the python code is giving me the following error.
Warning: IronPythonEvaluator.EvaluateIronPythonScript operation failed.
File “”, line 31, in
TypeError: ‘CoordinateSystem’ object is not subscriptable
Hey @chrisstaker welcome to our community forum!
That post and script are a bit old and things might have changed, what version of Dynamo & Revit are you using?
Any other edits to the script?
Could you share the stream with me so I can test it a bit?
Adding a link the tutorial as well: Mapping AutoCAD Blocks to Revit families with Dynamo
Revit 2020
Dynamo 2.3.2.15696
Stream - https://speckle.xyz/streams/38d1b50843/branches/main
I had to access the basepoint slightly different.
