Merhaba Emin,
Here’s what i think you can do to achieve what you want:
- We have Navisworks and Revit connectors. Depending on the use case, you can publish your model from either of these sources. I suggest Revit as it’s easier to navigate.
- Then you can export your timeline from Navisworks as an Excel/HTML/XML file and import it into Power BI.
- Then you need to relate these two data sources. You can use ElementID to relate these two data sources → Tutorial on how to relate two data sources
- You can use Gantt Chart etc. for the timeline effect.
@nikochin showcased how to use navis and power bi together for clash reports: BIM Clash report by Speckle and Power BI - Showcase! - Speckle Community
@Mohamed_Manseur showed 4D and 5D Simulation for construction phases - Showcase! - Speckle Community
Hope these resources help. Let us know how it goes.
