Only the texture will be enough🙃 this type of transformation might take a while especially if you have a high resolution of your rasters. You might save some time though, if you save both layers (texture and elevation) in the same CRS, so when the texture is being projected, it wouldn’t need to reproject every single point.
Let a lot of patience come your way
