Hi guys,
I want to update my Grasshopper connector but looks like I need to close Revit to do that. But why?
Hi guys,
Hey man, that’s because the two connectors (actually all connectors) use a shared library %appdata%\Speckle\Kits\Objects\Objects.dll
which needs to be updated together with the connectors themselves. That’s why you should always close any tool using Spekcle when you update/install/remove a connector.
