Hi everyone!!!
This is Enric Marques, a VisualARQ lead developer from Asuni!
I can confirm that VisualARQ custom objects are just Rhino blocks with extra features. Most of them are using an ECS (element coordinate system), so if Speckle is not applying the block transform, it is normal that they appear in a fixed position at the world origin.
I can also confirm that in some cases, there are nested blocks:
- If the user has a user instance definition that contains VisualARQ objects
- Some VisuaARQ objects contain nested VisualARQ objects (for example, a roof contains its slabs in a nested block).
Please, let me know if there is anything we can do to improve VisualARQ ↔ Speckle compatibility.
Thanks!!!
Enric
