This is an extract of an application I’ve made which creates rhino objects using the python library rhino3dm and add them to a rhino file. I want to send these rhino objects straight to a speckle stream but I’m not sure if I’m converting the objects to speckle objects correctly. Thanks
created_curves = []
admin_response = requests.get(adminboundaries_url, params=params)
if admin_response.status_code == 200 and admin_response.json():
admin_data = json.loads(admin_response.text)
if "features" in admin_data:
for feature in admin_data["features"]:
suburb_name = feature['attributes']['suburbname']
geometry = feature["geometry"]
for ring in geometry["rings"]:
points = []
for coord in ring:
point = rh.Point3d(coord[0], coord[1], 0)
points.append(point)
all_points.append(point)
polyline = rh.Polyline(points)
curve = polyline.ToNurbsCurve()
created_curves.append(curve)
att1 = rh.ObjectAttributes()
att1.LayerIndex = admin_layerIndex
att1.SetUserString("Suburb Name", str(suburb_name))
model.Objects.AddCurve(curve, att1)
speckle_server = "speckle.xyz"
speckle_token = ""
client = SpeckleClient(host=speckle_server)
account = get_account_from_token(speckle_token, speckle_server)
client.authenticate_with_account(account)
send_button = st.button(label="Send", key="mybutton")
if send_button:
server_transport = ServerTransport(stream_id='c883549443', client=client)
data = created_curves
speckle_geometry = speckle_objects.Base(data=data)
object_id = operations.send(speckle_geometry, transports=[server_transport])
client.commit.create(stream_id='c883549443', object_id=object_id)
To summarise, your backend serves GeoJSON, and you want to create Rhino Objects that you will share using Speckle.
You are nearly there in principle but there are a couple of key points for clarification:
You are attempting to send Rhino geometry generated with the Rhinoscript syntax - you need to use the Specklepy Objects API to create Speckle geometry. Specklepy doesn’t perform the conversions for you.
The Rhino Connector client plugin will perform conversion to Rhino Objects
How critical is it that you send a NurbsCurve specifically? If we generate a Speckle Polyline, will that work for you?
from specklepy.objects.geometry import Polyline, Point
if "features" in demo_data:
for feature in demo_data["features"]:
points = []
for coord in ring:
point = Point(coord[0], coord[1], 0)
polyline = Polyline(points)
created_curves.append(polyline)
If you need further help - or clarifications on next steps I can develop this further
Thank you so much for the prompt response, I’m starting to understand it a bit more however I keep getting this error now.
TypeError: Base.__init__() takes 1 positional argument but 4 were given
This is my current code.
created_curves = []
while True:
points = []
for coord in ring:
break # exit the loop if data is found
else:
time.sleep(0)
else:
# wait for some time before retrying
time.sleep(0)
Is it the way I’m sending the geometry or am I constructing the points wrong?
