I started using Speckle and I am currently using the provided default server “speckle.xyz”. Creating streams, branches, working with connectors etc works perfectly fine.
From the docs I got that I can use this server for specklepy tasks? I just can seem to make the connection:
from specklepy.api.credentials import get_default_account, get_local_accounts
client = SpeckleClient(host="speckle.xyz")
all_accounts = get_local_accounts()
account = get_default_account()
Returns:
SpeckleClient( server: https://speckle.xyz, authenticated: False )
and an empty list of accounts.
If I click on the link, it opens the normal web viewer. I got the latest version of the Speckle Manager installed and created an api token for my account.
Looks like you’re missing a few steps - please have a look at the docs as they explain and show how to do all this and more! The very first example shows you how to authenticate and use the client
# initialise the client
client = SpeckleClient(host="your-server.com") # or whatever your host is
# client = SpeckleClient(host="localhost:3000", use_ssl=False) or use local server
# authenticate the client with a token
client.authenticate(token=account.token)
If you have any more specific questions, feel free to ask away!
