I’ve tried installing the Speckle Connector for Revit 2022 and 2024, tried different versions (v1, v2, v3), the whole process seemed to run smoothly, but when I restart the computer / Revit, Speckle doesn’t show up in it. Any idea as to the reason why? Thanks!
Installed from https://app.speckle.systems?
Following the note we have in the new docs Why is the speckle plugin not showing up after I installed the connector, admittedly, it is a potential inception moment where that answer suggests posting back here, but if you could also check
- Do not install as an administrator for the machine, but as the current user
- Check
C:\Users\[YOUR_USER]\AppData\Roaming\Autodesk\Revit\Addins\2024
for
