After updating to grasshopper component 2.4.1 we started encountering a problem where we cant receive the streams because it gives a message that index is out of range.
This problem occurs on 2 systems here locally. The others aren’t updated to the newer component and I’m afraid to update them because it would cause delays in our implementation of speckle.
Hi @Jvpoel could you share the stream with us so we can test on our side?
I’ll try to reproduce your steps to see if it’s a quick fix and if so release a minor version to fix it. But it would help if we can also see the data that was sent from your computer
