Recently I formatted my laptop and made a clear installation. I have installed Speckle addin from Office store successfully but cant login. I get the following error:
Could not sign you in.
This browser or application my not be safe.
Try a different browser. If you are already using a supported browser, you can try signing in again.
I use my device in Turkish. Tried to translate it
I have tried to log in couple times and failed in all. Can’t find a way to change its browser from Edge to Opera/Chrome either. Any idea why I am getting this screen?
I am using Excel for desktop. I get this message after I try to login with a Google account. After I type my mail adress, without even asking for a password, it gives the above error.
I believe I haven’t login to my Gmail account through Edge or IE yet and looks like Excel uses Edge. I will try as you said when I get to my laptop. (I am currently at work )
Hi @teocomi , no firewall vpn or something. Just a normal windows 10 with normal firewall of course. The speckle app can log in without a problem. It is just inside excel where the issue occurs.
Hi @teocomi , thanks for your input. Turning the windows firewall off while logging in helped. After that I turned the firewall back on, and it still seems to be working.
Workaround definitely works, I tried the other “possible solution” but failed. I ultimately want to use it on desktop app (excel). Please can you suggest.
Can you please confirm what version of Excel Desktop are you using? If it’s an old version the only solution you have is to update to a newer version, unfortunately!
It’s actually newer than mine! Let me try to update and see if I can replicate it.
Alternatively, it could be that, if you are using a corporate computer, your IT department is blocking its access to the internet…
