Speckle Connector installed changes how Speckle Converter code works in another plugin
For future reference, if anyone is facing the same challenge, @AlanRynne’s answer was very helpful in coming up with the solution. Thanks Alan.
I’m not sure I implemented it correctly (?) but using the KitManager seems to work for machines with Speckle and for machines without Speckle.
Here’s the code for the initiation of our Speckle Controller ( / Connector) within our larger plugin.
        public SpeckleController()
            IsInitialised = Task.Run(() => Initialize()).Result;
        private Task<bool> Initialize()
            // This function initializes our Speckle Controller ("connector")
            // It tries to initialize the KitManager from a specific location on the user's machine
            // And if that fails, we assume Speckle is already loaded and there's no reason to load kits and converters once more
            var thisAssemblyPath = Assembly.GetExecutingAssembly().Location;
            thisAssemblyPath = Path.GetDirectoryName(thisAssemblyPath);
            // THIS IS THE PATH OF OUR OWN DEPLOYMENT OF THE SPECKLE KITS, OBJECTS AND CONVERTERS DLLs
            var specklePath = Path.Combine(thisAssemblyPath, "speckle");
            var appName = AppSetup.AppName;
            try
                KitManager.Initialize(specklePath);
            catch (Exception e)
                // Looks like the KitManager is already initialized, Speckle probably installed on this machine, ignore
            try
                var kit = KitManager.GetKitsWithConvertersForApp(appName).First();
                if (kit == null)
                    kit = KitManager.GetDefaultKit();
                // THIS IS THE MAIN CHANGE FROM PREVIOUS VERSION OF THE CODE!
                // INSTEAD OF CREATING A CONVERTER REVIT INSTANCE MANUALLY, WE HANDLE IT THROUGH THE KIT MANAGER
                converter = kit.LoadConverter(appName);
            catch (Exception e)
                Util.HandleError(e);
                return Task.FromResult(false);
            return Task.FromResult(true);
