Hello!
I tried to send a stream my model to Speckle server. Everything is good except Structural Column elements.
I tried in Revit2020, Speckle 2.4.0.
Here is the error report.
(New interface only provided limited information in the report, I used old interface.)
Object reference not set to an instance of an object.
at System.Object.GetType()
at Objects.Converter.Revit.ConverterRevit.CurveToSpeckle(Curve curve, String units)
at Objects.Converter.Revit.ConverterRevit.TryGetLocationAsCurve(FamilyInstance familyInstance)
at Objects.Converter.Revit.ConverterRevit.ColumnToSpeckle(FamilyInstance revitColumn)
at Objects.Converter.Revit.ConverterRevit.ConvertToSpeckle(Object object)
at Speckle.ConnectorRevit.UI.ConnectorBindingsRevit.<SendStream>d__9.MoveNext() in C:\Users\circleci\project\ConnectorRevit\ConnectorRevit\UI\ConnectorBindingsRevit.Send.cs:line 85
