Hi Speckle community!
I’m trying to run Speckle in a Rhino Compute script which I read here in your docs is possible, but I must be doing something wrong. I’m getting the following errors (screenshot attached). The first two appear to be Speckle related and I’m wondering if you know what’s causing them. I’m also attaching a screenshot of my Rhino Compute script. I’ve set my Speckle Url & Token via “Set Text” on the Speckle Model URL node. Then I’m using the Sync (Publish) node that the docs explained and simply uploading some meshes that I create in Grasshopper to a Collection. Any help is appreciated. Thank you!
