Hello Community, i need your help.
I’ve had the problem of Revit crashing while im moving the views on a sheet and trying to align them.
After checking every addin in the folders and using partially some of them, i came to the conclusion, that the Speckle addins where the ones (Link: C:\Users<username>\AppData\Roaming\Autodesk\Revit\Addins\202X)
After removing it, everything works fine.
Any thoughts why is this happening ??
This is the link to the video and a jpg of the error: SpeckleCommunity
Best Regards
We’ll look into this asap. To confirm, from your screenshots and videos: you’re using Revit 2025! Could you also let us know what version of the Speckle and Speckle Beta connectors you have installed?
As a last resort, we’ll ask for the problematic file if you’re willing to share.
Its the same result with revit 25 and 23.
The Connector i used is 2.21.5, released befor 5 days.
I’ve the older ones and installed them, but the error still occurred.
I suspect this issue may be related to switching views too quickly. We had this issue in v2 and we hope we fixed it in v3. Can you check if you still experience this problem with our next-gen Revit connector? Please uninstall the v2 connector and install the next-gen version from app.speckle.systems/connectors.
