I need help with receiving data to Revit 2019. My aim is to “downgrade” .rvt file from version 2020 to 2019. The 2020 file looks fine in speckle but when i try to receive it back in 2019 the file is still empty and a warning shows up:
Value cannot be null.
Parameter name: value
at System.Boolean.Parse(String value)
at Objects.Converter.Revit.ConverterRevit.ConvertToNative(Base object)
at Speckle.ConnectorRevit.UI.ConnectorBindingsRevit.ConvertReceivedObjects(List`1 objects, ISpeckleConverter converter, StreamState state) in C:\Users\circleci\project\ConnectorRevit\ConnectorRevit\UI\ConnectorBindingsRevit.Receive.cs:line 187
It turns out it was a bug in our version for 2019!
We’re indeed facing continuous issues with Revit 2019 because of how legacy it is, and it will be discontinued from the next release.
Nevertheless, @connor has fixed this bug and made a special release, to install it please use this installer so that it will not conflict with the Manager one:
