Not showing windows and doors from Archicad
Hey!
I have this problem with windows and doors not showing up after exporting from Archicad. Although the view in Archicad from which I saved the model contained these windows. Previously, there was no such problem in the same file. And after it appeared, it does not disappear with each subsequent update of the model. Why can such an artifact occur?
Hi @_Sergii_Holomah,
In Archicad, when you select an element, it only highlights the host elements. If you want to publish items like doors, windows, skylights, etc., you have two options:
  1. Use Shift + Click to select individual elements that you want to publish.
  2. Activate the corresponding tools (such as Door or Window) and press Ctrl + A. This will select all objects in that category (e.g., all doors, all windows, etc.).
This way, you can also publish hosted elements. Keep in mind that this is a feature of Archicad, not specific to Speckle.
Let me know if this helps!
