Hi Dimitri/Matteo/Cristi,
I have a Rhino model containing 17411 closed polysurfaces and would like to send it to our Speckle server, but so far I have only been successful in sending small amounts of from this model. When attempting to send a selection of 1763 objects through the Rhino connector, Rhino crashes. When I do the same in grasshopper, the conversion begins but then interrupts about halfway through and provides the error message “T0: One or more errors occurred.” The same message appears in the Rhino send report.
I have tried this on 2 different servers and tested with 2 other models but still no luck. Any thoughts on what could be causing this or how I could do to fix it?
I am running Rhino 7 SR14 with Rhino connector v.2.4.0, Grasshopper connector v.2.3.0 and SpeckleManager v2.1.25. The model is in millimeters, measures about 45000W x 56000L x 80000H and is located roughly 65700 from the origin.
Any support on this would be very much appreciated.
Thanks,
Simon
