Do you have any idea what could cause the issue ?
Looks like your token has expired. Can you log out from manager and log back in again?
Hi @Theox,
I was reproducing similar error on SU 2021 before, and with new pre-release, came up with a solution. Can you try again with 2.10.0-rc4
which is available under Versions tab.
Thanks for reporting!
Hope it will works. Let me know please if not.
-Oğuzhan
Wow !
Thank you very much it finally works ^^’
I’ll definitely use your plugin now to exchange data from the software I use !
Thanks a lot for the time you spent on figuring this one out !
Have a good end of week !
