How to call an object into the viewer using a room object, scope box, point
I’m using a translator, so the sentence may not be smooth. I ask for your understanding in advance.
I’m going to create a function to call out the objects that correspond to the coordinate values using the extents of room objects or scope boxes or point.
Does the Speckle viewer have the ability to call that objects as a coordinate value or spatially join(space-join) with a specific object to call that objects?
Summary
  1. Through point coordinates
  2. Through extent coordinates
  3. Through spatially join(space-join) with a specific objects
Hi @BIN628
So you want a function that checks if an object is within some bounds?
Not sure I understand the question here, but you can get bounds for each object here and here
We know language barriers can be tough, but usually you get decent translations with LLMs
Cheers
