It states 2 errors: 1. One or more errors occurred.
** You don’t have access to stream True on server https://speckle.xyz, or the stream does not exist.**
This is weird, since the stream is available online, but without any data
2. Could not identify any valid transports to send to.
Does anyone know if something has changed in how the sender interprets Revit objects.
I get the same erros when sending other Revit Objects such as Floors…
I can confirm that something weird is going on with those nodes, while we investigate, you can pass the right stream to the sender by URL, which is working as expected, so no need to downgrade.
Regarding the creation of Revit floor elements, we have individuated another issue for which we will release a fix soon today!
Upon further investigations, we found that this is just due to some crossed wires
The output of the “Update Stream” component is actually just a True or False value corresponding to if the operation worked or not. So you can rewire your definition as below:
