I’ve been working on a webapp to integrate some user inputs with the speckle viewer and plotly graphs.
I know it’s possible to colour objects based on the iframe url as pointed out by @jonathon
However is it possible to have a two way communication? Where you can grab the user input from the viewer. Say if they pick a filter to drive the input change for the Plotly Graphs. Much like PowerBI.
That would be awesome if anyone had any ideas on how to achieve this.
As I understand it, this isn’t a current capability of the SpeckleViewer in its embedded form.
Interaction between the SpeckleViewer and the Server frontend (which you can use at speckle.xyz) uses an event/listener buffer between the viewer and code on the same page.
Those events, as implemented, do not currently exit the IFrame security sandbox.
Cross-origin interactions across iFrame boundaries run into variable browser implementation/support.
Our recommendations at present for custom use-cases like this are to use the SpeckleViewer directly and then you have full access to the instance without security sandboxes.
