Feedbacks POWER BI - Speed
Hi everyone,
First of all, thanks a lot SpeckleTeam, the Revit-Speckle-PowerBI connectors are gold !!
Then, I would like to ask the community for feedbacks about how fast does PowerBI Desktop need to process the data you loaded from Revit through Speckle?
For example, when I am dealing with 500-600 Revit elements (doors or rooms), transforming or updating the data in PowerBI takes 15 to 45 min… which is super annoying :slight_smile:
Is it also the case for you guys ?
Thanks a lot for your feedbacks !!
Yes, we are aware. Currently, there is a limitation on PowerBI side when it comes to receiving objects. afaik it’s receiving one element at a time which is a super annoying and lengthy process. We are looking for ways to go around this limitation. I’ll let @AlanRynne explain the rest.
Hi @BaudouinNP!
Just bumping this thread to encourage you to test our latest versions of the PowerBI visual and the Data Connector, as both contain improvements in receiving/loading speeds.
As usual, you can download them from their respective releases page:
Don’t hesitate to get back to us with more feedback :raised_hands:t3:
