Elements tree how to do
my Elements like this,
how to do ,it is well like this
that is meaning elements under Data
Hi @baiheinet
How are you sending your data to Speckle in the top image?
The lower image is sent from Grasshopper, I presume. The “Data” is a List property of the commit object. You can nest lists of Elements repeatedly. The viewer will recurse that tree and display everything you have structured.
If you are sending from code, you can also replicate this.
From a Connector, each constructs committed data in different ways that make sense to the host application.
