Archicad (Send cancelled)
Hi @_Sergii_Holomah,
Thank you for bringing this issue to our attention. We are aware of this limitation and are actively working on a solution for our Next-Gen Archicad Connector. Due to the slow performance of Archicad’s API when extracting properties, we are considering implementing a feature that allows users to select specific properties to publish, rather than publishing all of them at once. However, please note that this feature may not be implemented if we find an alternative solution.
Thank you for your patience.
